05-07-2024 11:21 PM
hi, just a quick question. I recently looked at this new promotional plan $34 for 50gb canada and usa coverage. I just want to confirm, I am able to use the unlimited calls/text AND my data in the US for the same amount as well (50gb)?
Plans
05-22-2024 07:27 PM
In my Phone also data is not working in USA? I have to do ame ?
05-07-2024 11:31 PM
@TimPanda that is correct. You can use it in both countries as you like. If you run out of the 50gb in one country it also runs out in the other.
You have a VoLTE enabled phone?
In the US, manually add 4G/LTE and connect to T-Mobile or AT&T.
If calls don't work, put your phone to 2G and connect to T-Mobile. Turn on data roaming.
05-07-2024 11:28 PM - edited 05-07-2024 11:28 PM
@TimPanda yes, you can talk/text/data in US as like in Canada. Technically you can use all 50GB in US
just make sure you turn on Roaming Data on your phone and connect to either T-Mobile or AT&T
