03-07-2024
09:40 AM
03-07-2024
07:53 PM
computergeek541
Recently purchased $34 Canada /US plan .In checking data usage, in the past 3 days (March 4, 5 and 6th) , data between 40 and 120 mb per day were used between 12am and 1 am . There were two times of data use per hour . Does anyone have an explanation for this ?
Plans
03-07-2024 09:44 AM - edited 03-07-2024 09:45 AM
could be that's when Public Mobile updates the data usage.
03-07-2024 09:43 AM
No need to worry.
Public mobile only reports data usage once to twice per day usually early in the morning. It is the summary of your data usage. Not a live data tracker.
03-07-2024 09:43 AM
@Terry41 Yes because PM updates there usage 2x a day so your seeing the usage for the past 12 hours used
