200MB data reward doesn't show up
rh2025
On May 19, I redeemed 5 points for 200MB data. As of today, the data has not been reflected in my account.
The reward page says
Details
Extra Add-ons redemptions will be processed and visible in My Account within 24 hour. Data add-ons expire after 30 days.
As of today, the data has not been reflected in my account. Any idea why and how the 200MB data can be added?
Thank you.
rh2025
Thank you for the responses.
Have cleared my browser cache and used incognito but still not showing up. Have opened a ticket with CS.
slusagm
@rh2025 you logged in and clicked usage breakdown under that Usage meter and don't see the add-on?
Maybe try using browser with incognito mode and check again
If that does not show, ask PM. Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
Or message them using this link:
Chalupa_Batman
Details
Thank you.
Hello @rh2025
The app and website have cache issues. Just clear your browser cache and log back in incognito mode and it should show there. If it doesn't, you can reach out to a CS Agent this way.
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket. Enter CONTACT US into the chat and follow the prompts.
