Is there a typo in the 5 point add-on page?
Sashî
It says 200mb for 5 points but when I click on details it is mentioned:
Note: If you have just changed your rate plan, please wait 24 hours before redeeming the 1 GB data reward.
so I am slightly confused does this 1 GB reward refer to something else or is it just a typo.
Thanks
1 REPLY 1
@Sashî   if it shows  it just cost you 5 points , it is the 200Mb data.   The 1GB will cost you 10 points
I would take screenshot of the transactions and your points before you redeem it just in case.  If PM really deduct it worng, you can open ticket with them and show them the screenshots, just in case you need to
