Phone data
Rdes
Hi guys I recently bought a ulephone armor 21 and went about doing all the transfers went out and saw that my data inst working on my phone I've tried everything in the setting to make it work but nothing does wich makes me think it's the SIM card. Any idea
Rdes
Thank you so much!!!
@Rdes
voice calls work and just no data?
for Ulephone , you will need to manually update the APN for the data to work
Go to the APN screen, install of updating the current one, create a new APN profile based on below, make sure you save the new APN profile and set it as active
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
         or    default,mms,agps,supl,fota,hipri
           (might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
                or  Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D      (or try:   4D4F)
hi @Rdes
try Reset Network Settings on the phone and check if it helps
