Thursday
I switched from the old $25/1Gb plan to the new $19/1Gb plan that is also supposed to include a faster data speed. My plan renewed nearly 2 weeks ago and I’ve only used about 1/4 or my monthly data, but my data is still only 3G speed instead of 4G. What do I do about this?
Thursday - last edited Thursday
Okay boys and girls, stop bickering about data speed throttling. Data speed ≠ data consumption. There is no conspiracy theory with getting rid of the 3G speed cap. If we are going to be helpful to customers, we should be mindful not suggesting manual settings. For the less tech savvy, auto setting will produce best results.
Thursday
HI @RavingRaven
first time i hear people won't to "downgrade" so badly
Of course I know setting 3G is not the same is capping at 3Mbps. 20Mbps is still fairly good for a 250Mb usage. of course, if you really wait it capped properly, you know what to do, you have to ask agent for that
Thursday
I beg to differ. If you have a 5G speed plan set your data limit to 250mb and see how long your data lasts doing average tasks on your phone like checking email, doing the odd Google search and using google maps.
And setting your network to 3G does not throttle your data to 3mbps as the 3G network data speeds vary depending on network traffic but can reach up to 20mbps+.
Thursday
Happy to see it was a simple fix. I learned something new today.
Thursday
hi @Alicat27 happy to help
Yes, the community tries to help with quick fixes so you don't have to open ticket with support agent. 🙂
Thursday
hi @RavingRaven
honest, you won't loss much with a 5G speed unless you are browsing via video. a tip is to disable autopay on all video or music app
but the proper way, what you can do is to change the network mode to 3G and your speed will be capped by you.
Thursday
Why would that be lucky? Having 5G speed with 250mb of data is a disaster as your data is consumed at a much faster rate performing the same actions. There are still lots of customers with 3G plans and I would wager that if they stick with a 3G plan it's because they are quite happy with slower data speeds. Faster is not always better.
Thursday
Thanks -- I didn't realize there was a setting on my phone for this. Changing the setting on my phone fixed the problem -- glad it was so simple!
Thursday
@RavingRaven wrote:What do you suggest to fix the opposite problem? If your data speed is supposed to be throttled to 3mbps but it's 5G speed?
hi @RavingRaven
is this a "problem" you have? it is not even a problem
and if this is a new account, the speed might not be throttled on the first 48 hours and it will the capped after
However, there is no more 3G plan now so this won't be a problem
And if you still have a 3G plan but got 5G speed, it, more than 3Mbps on 4G or 5G networks, consider yourself lucky
Thursday
Thursday
check above, I made some suggestion
and @Alicat27 , one thing you can also check is to put your sim in another phone to confirm. Again, try different network mode and reset all networks when you are testing on another phone
Thursday
OK. What do you suggest to fix the issue?
Thursday
HI @RavingRaven
after the plan change, the account won't be throttle anymore. I think it is more a device issue and can usually be resolved without agent's help
Thursday
You need to contact customer support and ask them to raise a ticket with the tech team to unthrottle your data. Be sure to get the ticket reference # in case you need to contact them again if your data speed does not change within the time frame they give you for it to be fixed.
Click on the chat bubble at the bottom right to submit a ticket via the chatbot or send a private message by clicking below:
Thursday
@Alicat27 , I assume your phone is set to and connecting on either 4G or 5G? Are you using speed tests to confirm the speed throttling? Sometimes, local network conditions can lead to unreliable results. If you are sure that the data speed is still capped at 3 mbits/s, use the chat symbol on the lower right corner of the web page to initiate a support ticket.
Thursday
hi @Alicat27
what speed around you getting if you use the app SpeedTest?
make sure you change your network mode to Automatic and see that your phone showing 4G or LTE
if not, go to network mode screen and manually change it from Automatic to 4G or LTE
