08-16-2022 05:35 AM
Got a text that i have used up 100% of my data so i am trying to login to my account so i can upgrade my plan to the 20 Gigs 4g From 10 Gigs 3g But it is not letting me login, when will the MY ACCOUNT be back online? Thank you!
08-16-2022 08:00 AM
You shuld try different browser to log in or use incognito or private mode. Clear browser cache.
I do not experience any logging in issues today...
08-16-2022 07:50 AM
Now that you can log in check that you have used all of your data as pm does sometimes send out errant data usage texts. Then you can choose whether to change immediately (noprorating of your current plan) or schedule a plan change on next renewal. Once scheduled pm will honour any limited time deals on plans even if they expire before your scheduled plan change date. Rewards are applied upon your next renewal after a complete 30 day cycle.
08-16-2022 06:52 AM - edited 08-16-2022 07:52 AM
@Public_Man hi there was a maintenance issue overnight it seems, but I just tried and got in no problem,if you are still having problems try clearing your cache and cookies or try a different browser in ingognito or private mode,also sign in with a different device if one is avaliable
08-16-2022 05:50 AM
@Public_Man Wait a couple hours. To get an inmediate plan change, the $65 will be due immediately. There'a no refund from the old plan
