08-16-2026 03:19 PM
How long is the current limited time offer going on for? Specifically the $50/m plan with 175GB of data.
08-16-2026 06:32 PM
once it's your regular plan, it's yours as long as you keep up the payment or you change to something else. If you think the $50/175GB plan is something you can use...I'd suggest you take it while you still can. Bear in mind...once you take a plan like this with higher value...it's almost impossible to downgrade plans later on. Make sure this plan is best for your budget and regular usage.
08-16-2026 06:27 PM
HI @KeithToma
the deal was there since July 23th, so it has been 3 full weeks. I do not think this is a Back to School offer, so it might not last till Sept.
About Back to school, so Public Mobile could come with some Back to School deals as well. So, you can decide to wait or not to wait (but for your reference, over the past couple years, PM did not have Back to School offer every year)
08-16-2026 06:01 PM
Unless it is stated in offer itself it is unknown and it could be removed at any time. If you like an offer - take it ASAP.
08-16-2026 03:27 PM
@KeithToma They usually don't tell us the date when it will disappear.
3. Offer is available for a limited time and is subject to change or cancellation without notice.
If you need to contact PM Customer Support Agent, Start a Chat to Create a Ticket OR visit the Get Help page.
08-16-2026 03:27 PM
Thanks for the response.
08-16-2026 03:26 PM
We are just customers here. Since it is not said on that page, we cannot tell when it will end
If you like the plan and you just need a month or two to break away from your old provider, get it first before it is gone. You can order sim card and it will take time to arrive and it will give you 90 days to wait to complete the subscription
