07-31-2019 11:49 AM - edited 01-05-2022 06:12 AM
Hi, I'm going to Hawaii for a few weeks and want to change to the new $60 plan that has US Roaming. I am currently on the $40 plan but I have the RBC $10 off/month discount. Would I lose this discount if I changed plan?
10-27-2019 12:41 PM
Yes, it did help the decision, I ported in my wifes # onto that $60 account with the promos kept and just opened a new $25 account with the match price promo on now. Plus with the help of an amaazzzinnggggg mod @Silvio_M here, I'm all setup. Very happy.
10-25-2019 03:24 PM
@Alan_K wrote:
@lukevader wrote:
@Dunkman yeah, quite possible it could still be applied. But I even went as far as changing it to apply next billing period and there were no promos listed so I cancelled the change.
So until I get confirmation going the other way from 60 to 40 that the promo will still stick I'll consider it. If it doesn't I'll probably go down to the $15 plan.
Getting back to you asap on this @lukevader ! Hang in there while I get the answer for you
@lukevader Sorry for the delay. I've validated with the team and the 5 GB Recurring Add-On will stay, but the $10 off will not. Hope that helps your decision!
10-22-2019 04:48 PM
10-20-2019 07:28 PM
@lukevader wrote:@Dunkman yeah, quite possible it could still be applied. But I even went as far as changing it to apply next billing period and there were no promos listed so I cancelled the change.
Could you help confirm with @lukevader his question about if he downgrades his plan to $40 from $60, he will still get the RBC promotion of $10 off for 6 months. Thanks
10-20-2019 04:51 PM - edited 10-20-2019 04:52 PM
10-20-2019 02:36 PM
Public mobile wording/warning/etc can be ambigious at times. @Alan_K (the "boss" moderator/manager) mentioned that in previous post that the discount will still be applied. I guess if that fails you could contact moderators afterwards.
10-20-2019 12:24 PM
@Dunkman I hear ya, but the change bubble was very clear with before and after promos being applied. And see, thats the thing now, I don't really need this plan anymore... there's a better plan I learned about while down here. More data, more options, even works in mexico and canada.
10-19-2019 06:49 PM
You should still get the $10 monthly discount for 6 months. There is usually a warning if you change plans that you might lose different promos.
Just to be aware, the $60 US roaming plan is not available anymore. If you change plans, you will not be able to get that plan in the future.
10-19-2019 06:31 PM
@Alan_K wrote:
@twinpuller wrote:Hi, I'm going to Hawaii for a few weeks and want to change to the new $60 plan that has US Roaming. I am currently on the $40 plan but I have the RBC $10 off/month discount. Would I lose this discount if I changed plan?
@ShawnC13 Nailed it, a plan change to any plan of $40/mo or greater will not cause the promo to fall off. 🙂
I'm finding an issue with this statement... I am on the $60 plan and still reaping benefits of the USA perks cause I'm still down here as I type this but let's just say I found a deal TOO good to pass up down here to meet my needs for any usa roaming for a while.... soooo I don't really need this $60 plan anymore and the $40 plan will work just fine and when I try to change it, on the confirm changes popup I get a message confirming I will lose all my promotion add ons. The plan is still $40 or more, what's up with this loss of promo?
08-29-2019 04:14 PM
Does anyone know if RBC Avion Platinum card qualifies as a "rewards card" for the $10- 6 month discount? I do have rewards when I look at my statement but it doesn't specifically mention that card in the disclaimer posted. Waiting on RBC's answer if they know as well...
08-06-2019 01:53 PM
**bleep** that's too bad. I'm already in Hawaii and activated a different provider.
08-01-2019 11:59 AM
@Alan_K: Once again, mixed or ambiguous messaging between your announcement and the promo details. There shouldn't be different wording and there shouldn't be ambiguity. It just confuses everybody and then wastes *your* time trying to disambiguate it all.
08-01-2019 11:58 AM
@stonechucker wrote:
@Alan_K, can we assume PM will ensure this language will be in place in future such plans, as the current details are at best, confusing.
Yes absolutely, for future promos I will make a note to add clarity to plan change criteria.
08-01-2019 11:57 AM
08-01-2019 11:54 AM
07-31-2019 06:53 PM
I need to test this but the intended behaviour is you can keep it on a plan change to anything $40/mo or greater. Will loop back to you tmrw!
07-31-2019 06:10 PM
@ShawnC13 wrote:
@twinpuller wrote:
@GinYVR wrote:@twinpullerI don't think it is possible https://www.publicmobile.ca/en/on/plans/RBC-offer
Discount will expire if account becomes inactive or the rate plan is changed.
That's unfortunate. Thanks for your response.
@twinpuller, I would question this as it says $40 or greater plan and I think the part that says the discount will expire if account becomes inactive or rate plan is changed is meant to be to a plan lower that $40. @Alan_K can you clarify this for this customer. Am I interpreting this right that only a plan change to under $40 would lose the promo or is it any plan change?
Thanks, only problem I see is 2 sentences later it says discount will expire if rate plan is changed. I was hoping to get an answer today but I just went with another provider for my trip. It'll cost me a bit more, but it's ok... hopefully PM will have better roaming add-on rates in the future.
07-31-2019 02:01 PM
It wouldn't be the first time when fine print is a bit ambiguous. I also think that they meant if it is changed to cheaper and not to more expensive plan. Can anybody from @CS_Agent check?
07-31-2019 12:13 PM
07-31-2019 12:08 PM
The following statement is from the details of this promo. The promo will expire if rate plan is changed.
YMMV You are changing it to a higher cost plan. You may be able to keep the $10 credit. But it is better to check with moderator first. YMMV
$10 off for 6 months and 5GB one-time data bonus will be applied to eligible Ready-made rate plans of $40/month or greater. Bonus data remains on account until fully used but will expire if account becomes inactive or the rate plan is changed.
07-31-2019 12:03 PM
07-31-2019 11:59 AM
07-31-2019 11:59 AM
Was that promo linked to a specific plan or just had to be over a certain dollar value to receive the $10. Previous $10 off promos just stated that the plan had to cost more than $XX amount. I think you would be ok as you are going to a higher priced plan but I can't say for sure as I didn't look into the RBC promo as I was already a customer
