outgoing messages to 474663
08-24-2016 01:20 AM - edited 01-04-2022 03:06 PM
When I was checking the usage history, I saw a lot of messages sent to number 474663. Some of them happened at very similar time. However, I didn't make any of these messages and I could see them in the phone history. What are these outgoing texts for?
Service
11-18-2020 08:56 PM
It also spells "GPhone" 😁
11-18-2020 04:41 PM - edited 11-18-2020 04:42 PM
@Korth wrote:
It's apparently just something iPhones do. It apparently just stops happening after a while.
Apple apparently hasn't commented about this. Apparently nobody else knows why the texts happen or how to stop them. Even the xda devs have just shrugged it away.
These messages won't cost anything on any plan with unlimited texts. Every plan currently offered by PM has unlimited texts.
Odd that this would occur with Android. As I pointed out in this thread, 47466
LITERALLY spells out 'iPhone' on your dialpad.
As for being free, not everyone has the newer plans. Some still have legacy plans where text is limited, so it a concern for at least those customers.
As I pointed out in my case, this was resolved by simply resetting the iPhone to default settings and restoring a backup.
11-18-2020 03:06 PM
These messages won't cost anything in terms of "privacy" and "security". Because iPhones are already locked into whatever versions of those ideas Apple has provided.
You can use apps to block all radio traffic (at least after you jailbreak/root) but on iPhones it's all-or-nothing, you can't block items selectively.
11-18-2020 12:31 PM
@Buffalodon wrote:I talked to someone with an Android phone who was having the same issues so not just iPhones.
@Buffalodon this is quite impossible, unless they somehow have a super-secret leaked test build of iMessage for Android.
11-17-2020 10:33 PM
02-17-2019 08:18 PM
@21purplemiles wrote:My usage also shows outgoing messages to 474663. I certainly didn't send them but if it's an app, which one? Googled 474663 short code and found nothing
@Lieux wrote:Yes it was the same for me... @21purplemiles don’t worry everything will be fine after a few of them... you can write a message to the moderator...here...
https://productioncommunity.publicmobile.ca/t5/notes/composepage
And write moderator_team in send to and explain what happened... they will help you...not for stop them but they can give you a credit for them... if you have the 10$ plan with 50 texts outgoing included...
Like I posted above, 474663 spells iPHONE.... so the iPhone is doing something in the background. For me, it never stopped on its own. I took drastic measures to fix it because I would not figure out what in iOS was triggerring it, maybe iCloud related but could not solve it. Resetting the phone worked for me. Not sure if something less drastic will work.
02-17-2019 02:51 PM - edited 02-17-2019 09:31 PM
Yes it was the same for me... @21purplemiles don’t worry everything will be fine after a few of them..I didn’t do nothing special but they stopped. ...you can write a message to the moderator...here...
and explain what happened... they will help you...not for stop them now but they can give you a credit for them... if you have the 10$ plan with just 50 texts outgoing included...
02-17-2019 02:39 PM
08-06-2018 02:45 PM
No other message were sent to this number after the initial setup so I guess it's only an icloud thing going on.
07-09-2018 09:38 AM
What worked for me was a complete reset of my iphone 4S we inherited from a friend... which probably dealt with root casuse like iCloud or Messages.
Probably overkill but it cleared up the texts to 474663.... which BTW spells "iphone" (check it out!).
06-15-2018 05:42 PM
how to block or disable? can you go a little bit details?
06-15-2018 12:38 PM
Have you tried disabling I cloud?
06-15-2018 12:31 PM
I have the same issue. any one can provide a detail solution?
05-31-2018 10:19 AM
@robac wrote:Hi,
I had the same issue when I switched from Videotron to Public Mobile, there were 14 messages sent to 474663 in about 5 minutes when I activated my Public Mobile account based on my use history on my Public Mobile account.
After doing some research, it seems it is indeed related to iCloud being setup but those message should not be considered as real text message and therefore not counted as text message but since I'm on a 50 text messages plans, it seems that they are indeed counted in my total since it say that I have used 14/50 of my monthly limit.
I haven't seen any more text message being sent to that number since then.
Is there any official info from a Public Mobile agent to sort this out ?
any update? Seems I’m having this issue too...
05-15-2018 02:26 PM
Hi,
05-13-2018 10:00 PM
You can try blocking the number.
You can try completely disabling the text/SMS app when it's not needed (you might need a task-killer app for this on unrooted iOS devices).
You can configure all your background data and syncs to iCloud (or whatever) to only occur across wifi radio instead of cellular data.
It could be a malware. A "black dot" or "text bomb" thing floats around from time to time, it's apparently able to force iPhones to restart, it might be even able to disrupt other things - although I'm skeptical about the panicky claims of an incoming text permanently hacking, erasing, or bricking an iPhone.
08-27-2016 04:24 PM
08-27-2016 03:05 PM
@Kayfun101 wrote:
Ok solved it for real you need to take your iCloud off and re enter it so it does a reset from virgin mobile wean you re enter your details it should reset it so it does not show up on bill hope this helps you solve the issue ok
@xenophh can you please try this suggestion from @Kayfun101?
08-27-2016 11:17 AM
08-26-2016 06:04 AM
08-26-2016 05:59 AM
08-26-2016 05:55 AM
08-26-2016 05:53 AM
It's definately some sort of app
There is no charges associated with it
I suppose for troubleshooting you could list hardware type + what apps have been installed
Otherwise only other solution is to trace (but you need the physical phone to do that)
Public really has no way of looking into this
08-26-2016 05:51 AM
08-26-2016 05:51 AM
08-26-2016 05:09 AM
08-26-2016 01:42 AM - edited 08-26-2016 01:43 AM
I just switch to PM on my son iPhone5 from Virgin and I just notice that too in his usage history a lot of outgoing text to 474663
e
08-24-2016 09:45 PM
08-24-2016 03:16 AM
Interesting
Googling this short code gives virtually nothing (a few complaints from 5 years ago)
It must be from an app installed, only thing I can think of
08-24-2016 01:36 AM - edited 08-24-2016 01:36 AM
I haven't heard anyone reporting this issue. So, i doubt its from Public Mobile.
It could be some app that is doing that? or something else...
