09-12-2019 11:07 AM - edited 01-05-2022 08:53 AM
I set up a new phone using Public Mobile. The number and the data worked fine. Then I transferred numbers because I wanted to keep the number of my previous phone which was on Virgin Mobile. The number transferrred went smoothly. I can recieve texts but my data does not work. Any idea how to fix this issue?
09-12-2019 11:18 AM
Oh right. I dont have an LG but i restarted my phone and the data was working fine. Probably should have done that intially. Thanks
09-12-2019 11:14 AM
How would i fix this issue?
09-12-2019 11:14 AM
@DCM5 wrote:I set up a new phone using Public Mobile. The number and the data worked fine. Then I transferred numbers because I wanted to keep the number of my previous phone which was on Virgin Mobile. The number transferrred went smoothly. I can recieve texts but my data does not work. Any idea how to fix this issue?
Which phone are you using?
For LG phone, do a network reset after changing provider before your data working again.
09-12-2019 11:13 AM
Ok thanks. When I try to log in using my community account it says error logging in even though all the information provided is correct.
09-12-2019 11:11 AM
@Triguy wrote:Your port in incomplete. You would need to submit a ticket to a moderator by clicking on the questions mark on the bottom right.
I don't believe number porting is the issue. Data would work evem if number porting failed. I do, however, beleive that there might be an account data provisioning issue.
09-12-2019 11:09 AM
