System maintenance - On October 13th 2019, 00:00 ET - October 13th 2019, 10:00 ET
Silvio_M
Customer Support Agent
This means that between October 13th 2019, 00:00 ET - October 13th 2019, 10:00 ET
you won't be able to do the following:
  • Access your Self-Serve account
  • Activate a new account
We apologize for any inconvenience this may cause.
** Please do not post private info such as: phone number, account number, pin etc.. This is a public forum. **
9 REPLIES 9
Pmacfarlane
Hi,
We are experiencing a 404 error here when we try to register my wife's phone.  Its after you try to select a number.  Is there a system problem still?   This is continuous so new registrations are probably stopped.
Peter M.
@Judelina wrote:
You should have texted everyone i dont come on here everyday but getting a text i would get it
Disagree. Texting.customers who don't need to know will cause will cause issue. They will complain getting it every week. Customers want to know should check Community.
Judelina
CJ_in_Chilli
I'm glad I didn't go to buy my new sim in the morning...
Just thought I would report that during the activation process the system flinched at the number selection and jumped back with invalid sim error and also message that user name was in use.
The same thing happened with a different email and another sim. I then suggested to refresh the page and start over, process proceeded smoothly after that.
wingin
Thanks for the head's up..
Poogzley
Thank you for the adviced warning!
I hope the mantance will go smoothly despite taking place on the 13th! Smiley Tongue
At this point, I'm wondering if Saturday night/Sunday morning should be announced as a permanent maintenance window. Some websites do this every week.
darlicious
@Alan_K   Just a regular Mr-fix-it now.
hairbag1
Thanks for the hedzup...keep up the good work.
