Reply
Highlighted
Moderator
System maintenance - On November 10th 2019, 00:00  ET - November 10th 2019, 10:00  ET
This means that between November 10th 2019, 00:00 ET - November 10th 2019, 10:00 ET
you won't be able to do the following:
  • Access your Self-Serve account
  • Activate a new account
We apologize for any inconvenience this may cause.
** Please do not post private info such as: phone number, account number, pin etc.. This is a public forum. **
Highlighted
Re: November 2019 Wireless Proactive Maintenance - Wireless System Outage Notification
Thanks for the update!
Highlighted
@Alan_K @Eddy_G
May I sugest possibly renaming this the title of this thread? "November 2019 Wireless Proactive Maintenance - Wireless System Outage Notification" sounds alarming and as if the cellular service will stop working.
Highlighted
@computergeek541 wrote:
@Alan_K @Eddy_G
Agreed.  I suggest the title "System Maintenance - On November 10th 2019, 00:00 PM EST - November 10th 2019, 10:00 AM EST", similar to the last one on October 24th.
Highlighted
Thank you @Eddy_G
Highlighted
@Alan_K @Eddy_G
In the French annoucement, it does say that in the title for this upcoming maintenance.
Highlighted
Thank you for the heads up!
Highlighted
Public Mobile
Thanks for the suggestion @computergeek541 and @SD08 , I've gone ahead and changed the title.
Highlighted
Re: System maintenance - On November 10th 2019, 00:00  ET - November 10th 2019, 10:00  ET
I hope that this doesn't cause any renewals tomorrow to fail.
Highlighted
Thanks for the update. I also need help as I was trying to make a payment on my account but my visa debit is being declined. All my infos were all correct but still doesn’t work
