goggle news
02-24-2023 07:17 PM
I often use goggle news, however recently it has been so slow. I can scroll through the headlines, but if I click on an artilcle it just dies and then tells me "app not working". Does anybody have an idea.?
Thank you
Other
02-26-2023 01:37 PM - edited 02-26-2023 01:44 PM
Bravo and Thanks
02-26-2023 01:29 PM
It’s not you, it’s not your phone, it’s not the app.
Check here. . https://www.ctvnews.ca/politics/what-is-bill-c-18-and-how-do-i-know-if-google-is-blocking-my-news-co...
02-25-2023 05:37 PM
Curious did you actually get it resolved ?
Also Curious as how old your phone is and if it is
Apple or Android.
Lastly , I try to have a little fun with
GoGgle its meant as Fun and Levity not putdown or insult
Cheer
02-24-2023 08:30 PM
Try uninstalling the app and reinstall the app. There might be a glitch in the app the last app update.
02-24-2023 07:46 PM
Really, you would suggest factory reset for a potential user app issue? At worst uninstall and reinstall the offending app should be enough.
02-24-2023 07:44 PM
I would that that I recently needed to do an Update on an Android phone
I only use for WiFi for the Google Chrome app itself
Cheer
02-24-2023 07:37 PM
@cjshepard if other apps working fine, try to clear app cache , force stop and relaunch
If you can uninstall and reinstall, you might want to do that as well
02-24-2023 07:32 PM
It was on the news that google. Wes would stop working relayed to the lawsuit from. News sites wanting their fair share of the money so google news was stooping people. From reading the news
02-24-2023 07:20 PM
@cjshepard Sounds like a device issue , pain in the butt but worst case .. you can try a factory data rest and see if that helps .. z this wouldn’t be a PM issue service related … hardware issue I’d say
