telus email problem
02-26-2023 06:28 PM
02-26-2023 08:32 PM
Did you try connecting to #Telus then try login to your @Telus.net account?
02-26-2023 07:37 PM
Ok ok....here you go.
https://www.telus.com/en/support/article/set-up-email-android-phone-tablet-google
02-26-2023 07:18 PM
OP needs more detail
This could mean many things
Constructively its too ambiguous
02-26-2023 06:56 PM - edited 02-26-2023 06:57 PM
And if you use the gmail app....it will work there too. Just type in ron11@telus.net.
02-26-2023 06:53 PM - edited 02-26-2023 06:54 PM
This is not a PM problem.
OP should contact Telus for assistance to set up a Telus.net account. And it’s not really up to them to help either.
What email client are you using on your phone?
Some do it automatically. And don’t forget Telus email is now gmail.
If it won’t auto set up then try gmail...as all settings and ports are same.....then go back and change any gmail.com to Telus.net. Or google Telus for email settings for imap or pop.
02-26-2023 06:31 PM
hi @ron11 are you talking about login to My Account? what is the issue? do not use saved password if you have Telus account as well, the browser will get mixed up
if you are just unable to login, open ticket with CS agent.
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
02-26-2023 06:29 PM
@ron11 To change email you need supports help
- Get support by starting a conversation with virtual Chat box /SIMon. Click here
- you can send a private message To CS_Agents by clicking here.
Watch for reply top of page to the
Right ( envelope image )
