SIM card for European cruise ports
Darryl69
I'm looking for recommendations.  Would there be a sim card and service you would recommend that I could use (while on land) for all of these locations while travelling on a 2 week cruise?
Croatia / Italy /  Montenegro / Greece
Thank you! 😁
8 REPLIES 8
I used this one from UK Three before
https://www.amazon.ca/PrePaid-destinations-including-European-countries/dp/B01FI1JW72/ref=asc_df_B01...
But I got it in a local mobile store instead, price was around the same
JL9
Cruises these days are usually good with WiFi as well as many tourist ports so you may get by with a VoIP app on your phone as well.
Darryl69
I'll be spending some days in Rome so I would like service for the land days
@JL9 Cruise Wifi is pricey.  Unless you can redeem free , I would certainly stay away from it 😁
@Darryl69  The country list is long for the Three SIM, it works well.  Have a look at that.  But on the other hand, there are other brands providing similar service.  Check around
Darryl69
I'm a frequent cruiser so I usually have free wifi but I will look at "three sim"
Thanks
darlicious
@Darryl69
Is Croatia your first port of call? Prepaid SIM cards are cheap here and they roam likes home since they are part of the EU so no additional charges for the rest of your ports of call.
https://toomanyadapters.com/buying-sim-card-croatia/
To contact customer support :
Submit a support ticket via Simple--Simon the chat bot Click here
Or if you prefer or cannot submit a support ticket you may send a private message : Click here
To pre-verify add in your private messaging only your full name, address, email, phone # & 4 digit account pin #
Darryl69
We will spend a few days in Rome before embarkation so ideally we would like to buy a Sim card there.
darlicious
Here are some options for buying a SIM card in Italy.
https://toomanyadapters.com/buying-sim-card-italy/
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here   ....for additional member supplied info.
