03-23-2021 01:54 PM - edited 01-06-2022 01:32 AM
| 21/03/2021 10:58 | Outgoing Text | SMS | $0.00 | ||||||
| 20/03/2021 10:41 | Web | 0.008 MB | MB | $0.00 | |||||
| 20/03/2021 12:09 | Web | 0.004 MB | MB | $0.00 | |||||
| 20/03/2021 4:18 | Incoming text |
Looking at my Usage:
- I find TIME representation confusing. Make it either 24 clock (preferable) or add AM/PM.
- I am aware of 'data leak' and as seen above it does exist. Could somebody explain why is this happening even though my 'data' is off all the time and could Public Mobile do something about it on their side?
03-23-2021 03:45 PM
Set your phone to a 24 hour clock to make comparing your calling/texting usage logs between your account and your phone easier.
Data leakage is not necessarily counted against your plan data. I have data leakage recorded in the daily usage pages long after the plan data has been completely consumed. This is not MMS data usage but recorded as WEB usage.
03-23-2021 02:59 PM
TOTALLY agree they should utilize 24-hr time -or- AM/PM designation.
Adding insult to injury, calls show as local time, and texts display as EST, so that further aggravates the timing of said items.
Maybe it'll be part of the routine self-serve and Community upgrades which appear to be routinely underway - one can hope!!!
03-23-2021 02:03 PM
When you turn on your data there is a 5 MB buffer then it gets reset.
https://productioncommunity.publicmobile.ca/t5/Using-Your-Service/Android-OS-Leakage/m-p/571012
03-23-2021 02:03 PM - edited 03-23-2021 02:13 PM
@Meow wrote:
21/03/2021 10:58 Outgoing Text SMS $0.00 20/03/2021 10:41 Web 0.008 MB MB $0.00 20/03/2021 12:09 Web 0.004 MB MB $0.00 20/03/2021 4:18 Incoming text
@Meow Yes and it's been suggested more than a few times before that it's confusing the way PM doesn't record the timestamp and most likely, like a few other things around here, it's not a priority for them to fix.
Your phone log actually does provide the exact time of your all calling and texting though, so probably why it's not mentioned more often I'd think?
Edit: Oops didn't realize you were worried about when your data is used, sometimes that can be system apps that work in the background, I think. Seems to be very small amounts.
