02-07-2022
03:27 PM
02-07-2022
06:02 PM
computergeek541
FaceTime calls keeping shutting down.. is there any updates that I’ve missed? My internet carrier is thinking maybe that’s the cause..
02-08-2022 09:07 PM
Can be weak wifi or data on either side of discussion.
02-07-2022 06:00 PM
Doesn't sound like iOS 15.4 to me. if it is 15.4, it won't connect to Mobile Data
@Spir9193 What iOS do you have? You might want to update it to the latest stable version. just DON'T try the iOS 15.4 Beta. It is not compatible with PM.
02-07-2022 05:54 PM - edited 02-07-2022 05:56 PM
IOS 14 had a lot of issues including FaceTime.
The latest IOS 15.3 fixed most issues including FaceTime but there is still issues on my System Data…my iPhone is using over 30gb. It should be around 10gb.
If you are on the IOS 15.4 beta, you will need to remove the IOS 15.4 beta to the public IOS 15.3.
There are issues with IOS 15.4 beta with 3G frequency which PM is on.
02-07-2022 03:37 PM
Hi @Spir9193
on Wi-Fi has same issue ?
if your IOS 15.4, then you need to try downgrade iOS some report has a issue with data..
How to uninstall iOS or iPadOS beta software - Apple Support
