Balance missing
Aaqil78
I had balanced amount. Now it’s missing
geopublic
@Aaqil78Dial *611 from you phone is the balance still not correct?
dennise3388
If the balance is missing, please send an email to moderator team. They will investigate the situation.
BEER
Most likely your plan renewed and the balance was applied to the charges.
NDesai
@Aaqil78 It happens from time to time. Try using incognito/private browsing mode. If that does not work, you can go to My Rewards page and it will show you the amount due. Even if that does not work, you can dial 611 and you will hear the amount due.
hairbag1
Has your plan renewed lately ? PM will take renewal from Available Funds before deducting from your registered credit card.
Does that sound about right ?
