New Point System
Chalupa_Batman
This was posted on Reddit. Can anyone confirm this is accurate?
With old Rewards:
  • you're getting $2 from AutoPay
  • you're getting $5 from Loyalty
  • it's automatically credited to your account balance
  • this is saving you $7 per month = $84 per year
With new Points™:
  • you'll get 5 Points™ for signing up (even if you're being forced to sign up)
  • you'll get 2 Points™ from Referrals per month
  • you'll get 10 Points™ from "loyalty" at the end of each year
  • you'll get 5% of what you spend (pay for your plan and add-ons) as Points™
  • you can login to your account and spend Points™ (once you have 15 or more Points™)
  • this can save you about $15 per year (maybe a few extra bucks on the first year)
fixin1
@Chalupa_Batman - Okay, just making sure that I am looking at the correct post.
Yup @fixin1 that's the one.
fixin1
@Chalupa_Batman - From this one?
EDIT: Removed swearing from image.
https://www.reddit.com/r/PublicMobile/comments/1c588d8/comment/kzsrdbd/?utm_source=share&utm_medium=...
I can definitely confirm this on Legacy Side:
  • $2 from autopay
  • $2+ from Loyalty
  • Auto credits
  • Refer-a-friend = $1 off
  • $2+ guaranteed
With The Points:
  • 1 points per referral
  • Wider variety of choices to use on points
  • 10 points every year (Confirmed with one account)
  • 5% from spending on plan amount (Unsure with add-ons)
  • Earn at least 20 points annually.
With new Points™:
The above point isn't correct. It's only 1 point per referral.
