06-01-2019 08:52 AM - edited 01-05-2022 05:10 AM
08-07-2019 12:33 AM
@Anonymous wrote:We'll see next if and when I use the 50 where it comes out of. So someone else needs to observe things until then. 🙂
@Julia_T and the thread:
To update...I can attest that this now goes to the 500 minute add-on instead of the 200. I've used the 50 and it carried over to the 500 for Canadian calls.
06-13-2019 01:07 AM
@dabr wrote:
@Anonymous wrote:
@mimmo wrote:@Anonymous
This is the reply I received. If you had different experience please report to @Julia_T
It does not matter what order you've added the add-ons.
If you have all 3 LD talk add-ons and call within Canada, the order which minutes will be depleted from will be: rate plan allotment (if possible), Canada-wide, then Canada-US, then International.
@mimmo: and everybody really...I received a lovely reply back from Julia_T that they say they have fixed the issue. I just renewed so I won't be testing it anytime soon. But they say it should make more sense as to the order of consumption now. Plan minutes, 500, 200, 400.
I didn't have the 400 but it DID go to the 200. It should have gone to the 500. So now it should. Rock and roll.
Thanks Julia_T.
Nice to hear it got sorted, hopefully they credited back all your minutes too, and that PM techs have fixed the glitch:)
They didn't adjust any minutes but it's not that much to make a deal about it. There was one cross over call that finished the 50 and then went over to the 200 and then the rest came out of the 200. I mostly made a bunch of useless little test calls and such that maybe come to another 10 minutes maybe. I don't need them examining my call history THAT much 🙂
They gave me a system issue credit and then re-installed the 500.
I'll reserve petty little dickering for when it's not petty.
06-12-2019 10:35 PM
06-12-2019 10:30 PM
@dabr @fanfan @Someone_here @geopublic Our technical teams have been working hard on this issue and I'm glad to let you know that a fix has been put in place. Starting today, when calling somewhere in Canada, minutes are used in the right order - first from a customer's rate plan (if relevant), then Canada-wide addon, then CAN-US addon, and then INTL addon
Thanks all for the feedback!
06-12-2019 10:09 PM
Thanks Julia_T.
06-12-2019 09:12 PM
Thanks Julia_T.
06-03-2019 08:55 PM
@geopublic wrote:
@dabr wrote:
@Someone_here wrote:@dabrI agree with you but think they should take it one step further, maybe put less stress on the programmers.
Add-ons should be changed as follows:
- Canada Only
- Us Only (Remove Canada)
- International Only (Remove Canada and US)
Agree! That would really makes everything so much simpler.
I don't really want to have to buy two (or three if on provincial calling plan) different add-ons... I am fine with one that does everything (the when the need shows up), even if it is a little more expensive (the 400 minutes/$15 one) 😉
I have nothing against the new Canada only add-on, but just to say I don't think the US and the international add-ons should exclude other cheaper options!
Ideally there only needs to be two options, one for Canadian and one for international, but I'm guessing $15/400 mins might be considered too expensive for some users need. There's never going to be a perfect option, but I'm really happy with the current add-ons which are quite inexpensive.
@dabr The Canada only add-on is a requirement for those who are on limited or Province wide talk plans.
I did say that PM could offer one add-on for Canada wide minutes (new add-on) and one for international minutes. But really I'm not too bothered either way so long as people aren't confused between the US/Canada minutes and Canada only minutes 🙂
06-03-2019 08:49 PM
- Canada Only
06-03-2019 08:40 PM
- Canada Only
06-03-2019 05:35 PM
Over here @pm-smayer97. surreyboz managed to stumble across it and started this thread.
I picked up one immediately.
06-03-2019 04:55 PM
- Canada Only
06-03-2019 03:19 PM
@geopublic wrote:
@dabr wrote:
@Anonymous wrote:
@dabr wrote:So are you saying, after your plan minutes are depleted this new add on won't be used first for Canada wide minutes, but instead the US/Canada minutes are getting deducted? That would be a bit concerning. Maybe there needs to be a tweek to this new add-on to allow for Canadian calls to be utilized first.
That's exactly what I'm saying. So...someone needs to buy the 500 minutes, use their 50, use a couple of the 500, renew their plan, buy the 200 minutes, use their 50...see what gets hit next.
It might simply be order of purchase. Dunno.
I would be fine with it the other way around now after the fact...if I were to use up the 200 and let it start in on the 500 then buy the 200 again for US calling but call Canada and see what happens. If it kept taking from the 500 then I would be fine with that except what happens after I use up the 500. 🙂
Maybe PM just needs to retire the 200 mins for US/Canada now with the new add-on being a much cheaper option for supplemental Canadian calling compared to the 200 mins anyhow. The 400 minute add-on works for US calling too so not really necessary for the duplication, other than maybe a smaller bucket of mins for people who don't want to pay $15?
- Canada Only
06-03-2019 03:14 PM
06-03-2019 03:13 PM
Julia_t was the one who replied to my question. That was why I mentioned her. If you have experience that differ from what she said reply to her.
06-03-2019 03:05 PM
@Psygineer wrote:
@mimmo wrote:
@Psygineer wrote:This might be good for my parents. They have unlimited province wide (the old $20 plan), when I travel for work, they can't always reach me. Adding this would fix that and be cheaper than upgrading them to the $25 plan. (I don't travel that often where I am out of their calling range, only a few times per year).
@Psygineer I dont understand the issue here. are you saying they would say call your hotel which is in another province? if they are calling your cellphone it should not matter where in canada it is your parents would always be calling local number.
Call my cell. When I was in Winnipeg last (as an example) which is outside of their province, they were unable to call me on their Province wide plan. They were given the canned message of it being outside of their package and they needed an addon. My Area code and theirs is Ontario based.
This shouldn'd happen...
See this image from PM: https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Plans-amp-Add-Ons/ta-p/250167?lightbox...
If it does it again next time maybe worth contacting the mods so they give it a look.
06-03-2019 02:55 PM - edited 06-03-2019 02:59 PM
That's good to know, although I believe @Anonymous saw the deduction from his US/Canada minutes first?
I did have a different experience and have mentioned it all to Julia_T. I also tested an outgoing to Canada and it took from the 200.
It doesn't make any sense if the Canada minutes are to be taken first. Hopefully, you'll hear back soon to explain why that's not happenning.
As many of us are aware, there are several quirks in the system around here :). Some go our way. This one does not.
I gave you the Bravo but thanks for asking them @mimmo.
06-03-2019 02:53 PM
06-03-2019 02:50 PM - edited 06-03-2019 02:52 PM
I did have a different experience and have reported it to Julia_T. I also tested an outgoing to Canada and it took from the 200.
06-03-2019 02:46 PM
06-03-2019 02:44 PM
@dabr wrote:
@MandyJ wrote:Question: I get that add-on "leftovers" transfer into the next month until they are used up, but do they stick around if you switch to a different plan? I was considering buying some for down the road when I might need them 'just in case', but since I have no actual need for them right now, I wouldn't want to buy them just to lose them later if I switch to a different plan.
Yes they're not connected to the plan but your account.
Awesome, great to know. Thanks!
06-03-2019 02:43 PM - edited 06-03-2019 02:44 PM
Yes they stay because they're not connected to the plan but your account.
06-03-2019 02:41 PM - edited 06-03-2019 02:42 PM
Question: I get that add-on "leftovers" transfer into the next month until they are used up, but do they stick around if you switch to a different plan? I was considering buying this addon for down the road when I might need them 'just in case', but since I have no actual need for them right now, I wouldn't want to buy it just to lose it later if I switch to a different plan.
06-03-2019 02:34 PM
@Anonymous
06-02-2019 07:50 PM
Nice
06-02-2019 08:41 AM
@Psygineer wrote:That's tempting, but with the $20 unliminted province wide plan being gone, I'd be concerned my mother would burn too many minutes. She sometimes talks to her sister for over an hour at a time. I'd be unable to go back to the old plan. Mind you it would still be cheaper if I only had to add the addon once every other month.
You can still get the $20 unlimited province wide talk with NO text and no data if you go through the build your own plan method. I did that the other day for a friend.
06-02-2019 08:28 AM - edited 06-02-2019 08:31 AM
Heck Spy...save them 5 bucks and drop them down to the $15 plan and that add-on and they'd be rockin'. And some data for goofin' around.
06-02-2019 01:37 AM
06-02-2019 12:15 AM - edited 06-02-2019 12:17 AM
06-02-2019 12:06 AM
06-01-2019 11:53 PM
@fanfan wrote:I think one more suggestion to add on your procedure above to help add some clarity.
This is for someone who is on the $10 - 50 min plan and Has NO current add ons.
Step 1 : Buy the new $5 - 500 min Canada-wide minutes add on first.
Step 2 : Buy the $8 - 200 long distance Canada/USA minute add on.
Step 3 : Use up all your remaining $10 - 50 minutes.
Step 4 : Make a local call and see what bucket the minutes are deducted from
Step 5 : Make a long distance call to somewhere in Canada and see which bucket is deducted.
Step 6 : Make a call to the USA and see what bucket the minutes are deducted from
If the USA call goes thru and minutes deducted from $5 - 500 min bucket, then you discovered to good glitch.
Step 4:
Except the $10 plan is Canada-wide so there's no such thing as a local call. Even just for the province-wide, a traditional land line local call is irrelevant when calling the province.
Step 5:
Canada-wide...it's not long distance.
I've had my 200 minute add-on since September. I'm not going to cook through it just to test. 🙂
