09-03-2019 11:14 PM - edited 01-05-2022 06:51 AM
It is absolutely ridiculous that PM does not push APN settings to a device and even more assine that you lock the APN settings so that users can't add them manually.
I bought a new phone and can't use the data I'm paying for because of this nonsense. So you need to resolve this of give me my money back as you are not providing me with the service I've paid for.
Phones
09-03-2019 11:56 PM
@Anonymous wrote:
@ReallyPissedOff wrote:Nope, they are locked and I'm on PIE.
I've seen it mentioned here that just to the left of that magnifying glass symbol (search) there's a kind of hidden + (plus) sign for adding.
I'm not sure I've seen it proven out but maybe it's there.
Selecting one of those doesn't let you edit with the 3 dots?
I remember back in the android 4 and earlier days, the dots revealed a menu. I am on android 9 and the dots only bring up the reset function. The add APN function + sign is right next to search, totally in full view.
09-03-2019 11:52 PM
@ReallyPissedOff wrote:Why doesn't PM just push the APN, it's pathetic that they force you to add/edit an APN to get data.
This is how android handles APNs. There is a file called apns-conf.xml that resides in the system partition containing the available APNs that the OS can choose from. Depending on the SIM card that is inserted into the phone, the OS will try to pull from the file what is believe to be possible matches. Some OEMs do not provide a full set of APNs and as a result, the user is then required to manually enter one. This is the situation you are facing. Some editions of android had the add APN function disabled through default settings (I think it is in build.prop). Android 8.1 is generally the version that had this issue. It seems like Asus somehow carried over these bad default settings into the your phone OS and at the same time provided a less than adequate set of APNs. Asus is not a carrier brand and so there is no conspiracy theory here that points the guilty finger at Public Mobile. The problem is totally with the hardware OEM.
BTW, my android experience has been pretty much 100% with unsullied android roms either pushed by google or via third party developers. I have never had a phone where I needed to manually create my own APN. AOSP has always included a well stocked apns-conf.xml.
09-03-2019 11:52 PM
09-03-2019 11:50 PM
Why should I have to crawl through the dirt in the dark in the middle of a storm to fix PM's issue?
I had to add the APN in my previous phone, so this is a PM issue.
09-03-2019 11:48 PM
09-03-2019 11:46 PM - edited 09-03-2019 11:50 PM
@ReallyPissedOffThere is no "Google Policy" regarding APNs or locking. APN existed way BEFORE Google Android existed, the format was agreed on even before Google.
Another company you should write to complain is Asus. They are the ones that are in charge of the customization of the phones and they are the ones who didn't update the database and add Public Mobile in their Android OS builds only Telus and Koodo.
You can always use adb to add your APN if you wish, swapping SIM cards is not the only way.
09-03-2019 11:42 PM
I guess that depends on the device. I never had to enter or change any APN settings on Pixel 2 and 3. It automatically loaded the correct settings.
Ditto old BB OS10, S7 with A8. Nokia Windows Phone 8.1 needed a little massaging but able to do it and works fine.
09-03-2019 11:37 PM
09-03-2019 11:34 PM
09-03-2019 11:33 PM
@ReallyPissedOff wrote:ASUS 5Q running PIE.
If you are on Pie (9.0), then you should have access to edit the APN settings instead of choosing Telus/Koodo.
09-03-2019 11:31 PM
@ReallyPissedOff Have a look at this Reddit post, it might help.
09-03-2019 11:29 PM - edited 09-03-2019 11:34 PM
@ReallyPissedOff wrote:I can add an APN with a SIM from another provider, but only get Telus and Koodo's APN when I add the PM sim.
You're going to have to also point the finger at the phone manufacturers. This is a phone softeware issue. I do not know if Public Mobile sims have some type of code that prevents alterations on APN settings, but it just wouldn't make any sense for that to be the case. They'd have nothing to gain from this.
Many phones running Android 8.1 and with Public Mobile sim cards inserted do allow new APN settings to be added, even if they don't allow editting of existing APN. Some phones do not allow it. This is an issiue that crept in with the stock release of Android 8.1. Any of the phone maufactuers could override this restriction, and some in fact, did.
09-03-2019 11:29 PM
09-03-2019 11:28 PM
Yep, tried that, the minute I put the PM sim back in the PM APN I created goes away.
09-03-2019 11:27 PM
@ReallyPissedOff I bet you are on Android Oreo (8.1). This is a know issue where users can't edit the APN settings. What phone are you using? May be there is workaround to add a new apn settings?
09-03-2019 11:27 PM - edited 09-03-2019 11:31 PM
I tried that, the option is there, but the APN PM setting goes away when you put the PM sim back in.
I spent almost 18 years working at the head office of another provider, including a period of time in software developement, so I know what I'm doing.
This is 100% a PM issue.
09-03-2019 11:27 PM
What some people have done in the past was to use the other carrier's SIM card to create a new APN Setting that matches the PM setting, save it. Then re-insert the PM SIm card and use the saved manual setting.
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
09-03-2019 11:25 PM
So use that other SIM and add the APN info that this place needs and then insert this SIM and select the APN and that should work. Remember to save and restart as appropriate.
This is not a problem only with this place. Many other carriers have similar issues.
09-03-2019 11:19 PM - edited 09-03-2019 11:19 PM
09-03-2019 11:18 PM - edited 09-03-2019 11:19 PM
Because they are the ones who have decided to follow Google's policy.
09-03-2019 11:17 PM
@ReallyPissedOffPublic Mobile doesn't sell phones.. so why do you think they would lock APN settings? If you want to blame.. write to Google to complain, it is Android that is the hot mess.
- « Previous
- 1
- 2
- Next »
