Order 160005 - Wrong Address
03-12-2019 11:02 AM - edited 01-05-2022 06:51 AM
Hi Public Mobile,
I'm sorry but I misspelled my postal code when I ordered a new SIM card. Could you update it. Hope its not too late.
Thanks a lot.
Cheers,
Dom
Service
03-12-2019 03:09 PM
@Dom2 wrote:Hi Public Mobile,
Thanks a lot.
Cheers,
Dom
Canada Post has methods to correct postal codes. It is possible that this could cause the envelope to be delivered to the wrong address, but more likely, it will be sorted to the wrong area, then sent back to the mail depot where someone will likely look for the most likely matching address/postal code combination It'll probably just add a few extra days to the delivery process.
03-12-2019 12:23 PM
Even if it has already been shipped, if the postal code is the only thing wrong with the address, it is likely to still be delivered, there may just be a delay.
03-12-2019 11:09 AM
Thanks@mimmo for the hint. I will send them a private message. Hope it's still in time. Fingers crossed.
03-12-2019 11:04 AM
@Dom2 best to send a private message to the moderator_team and see if tehy can fix the postal code.
