creating an account or setting up auto pay
jcoffee
I have been trying to create  an account to create auto pay i am not able to do so. I need help please and thanks
9 REPLIES 9
@jcoffee are you able to log in your self serve account?? Did you try many passwords and it's blocked now? You will need to wait 1 hour before try again.
If you have still problem write a message to the moderator for help..
and explain what happened with your registration. They will help but waiting time few hours to 2 days.
missorange
Try "forgot your password" if telling you already registered.
Have you tried logging in?
jcoffee
telling me I have already registered which i have not registered
jcoffee
i have tried that it is not working
courtneydunn5
What is the problem you are having? You can try using a different browser or a different card.  Some times certain debit visa cards do not work.
Metal1967
@jcoffee
What issues are you having while trying to set it up?
will13am
@jcoffee, although not mentioned, I assume that you have activated the service at a retail partner and you are trying to just set up the online access.  This is the link for do that.  Just follow the prompts and everything should work.
https://selfserve.publicmobile.ca/
Alex888
What are you having problems with? If you keep getting error messages try a different browser or mode, Chrome in incognito usually works.
