Reply
Highlighted
Sim card.
Can I take my Public sim card out of my phone and put it to my laptop and use my data plan to get on and use internet.
Accepted Solutions
Highlighted
Re: Sim card.
You should probably use the hotspotting feature of your phone instead to access the data on your laptop.
All Replies
Highlighted
Re: Sim card.
Highlighted
Re: Sim card.
@gp2  As @dabr  mentioned just turn the hotspot setting on your device and make a note of the connection password then scan for networks on your laptop and connect to the hotspot and you should be able to access the internet on your laptop.
Highlighted
Re: Sim card.
Yes, if you have a cellular laptop that supports PM's frequencies AND you can configure its data connection correctly.
>>> ALERT: I am not a moderator. Je ne suis pas un moderateur.
Highlighted
Re: Sim card.
You could bur why? The reason people do it is because there are some data-only plans that are cheaper than plans with voice.  If you're paying for voice, with forgo it?
Highlighted
Re: Sim card.
Thank you, I finally got it hooked by tethering with USB port.
Highlighted
Re: Sim card.
Hi there, Tried to do that and it tells me " can't connect " But I finally got it hooked by tethering with USB port.
Highlighted
Re: Sim card.
Thank you, I finally got it hooked by tethering with USB port, works fine.
Highlighted
Re: Sim card.
I do a lot of work on my laptop that I can't do on my phone so I need this when at the cabin and I finally got conected by tethering it. Thanks.
Highlighted
Re: Sim card.
Good to hear you found a way to make it work for you.  Thanks for the update.
