Reply
Highlighted
Invalid siim
Recently re activated an existing sim card that I wasn't using for a little while. (new device now) All paid up and account shows its all good. Now, when I log into account and enter Sim card number to activate it... It says invalid Sim number.
1)Any idea why?
2) im trying to contact public Mobile so I can add my imei number so this Sim card will work in my new device. Is this the way to do this?
Thx
Accepted Solutions
Highlighted
Re: Invalid siim
@JohnoRono wrote:
What plan and phone are you using?  If it's a 4g plan then it won't be compatible with your phone.
Plan type has no relation to phone comaptibility. All Pubilc Mobile customers have access to both 3g and LTE networks (dependent on compatibility), regardless of the price plan.
All Replies
Highlighted
Re: Invalid siim
1)Any idea why?
Thx
If your SIM card has been inactive for over 90 days you will need to purchase a new SIM card.
* I am happy to help, but I am not a MOD please do not include any personal info in a private message to me, click here to private message a Moderator *
Highlighted
Re: Invalid siim
When I bought a new sim card it did this aswell, I just used a different device to put info into. If that's not possible try an alternate browser
Highlighted
Re: Invalid siim
Sim wasnt over that 90 day period and account now shows it as active once they took my payment. But still shows as invalid Sim number when I try to enter it into the form.
Highlighted
Re: Invalid siim
IF you are just reactivating your plan you won't need to go to change SIM or anything like that.  AS LONG AS it is under 90 days you pay for your plan and everything should be good to go.
Highlighted
Re: Invalid siim
Why are you activating a sim? It says invalid because it'a already being used. Did you lose your old sim?
Highlighted
Re: Invalid siim
@Oilersman  Have you put the SIM in your phone to see if it works?
Highlighted
Re: Invalid siim
@Oilersman  No need to reactivate the sim card. As long as you reactivates your account just insert your sim into your device and it should work. If not submit a ticket to PM.
To submit a ticket to the Moderator Team, please start a conversation with the Public's virtual assistant, SIMon by clicking the icon below:
If you are still having problems contacting Public Mobile then click here. The link  sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
Highlighted
Re: Invalid siim
Ok. What I am trying to do is this... Use my good working Sim card and put it into a gps tracker. This worked 100% with a different provider (Rogers) but it was too costly. This sim card is public mobiles from an older phone of mine.
I'll have to ensure that the sim card is functional later by putting it into another phone. I'm sure it is though. I just am wondering now if it'll work for the gps tracker. It just needs 3g network and I do have that plan. Can't be much difference from Rogers to public?
Highlighted
Re: Invalid siim
What's the model of the GPS? As it has to support public mobile frequency bands..
