05-04-2022 07:44 PM
I just got a new phone.
I installed PM SIM , why do I have no data on my new phone? I am on $15 plan.with 250 M data/ month.
HOW TO set it up ?
05-04-2022 08:05 PM
Always refer to your self serve account for accurate data usage. Did you toggle wifi off by a mistake or download apps with data or data assist without knowing it? Or have you not had data for a second, then as @dabr says it could be an APN issue
05-04-2022 08:03 PM - edited 05-05-2022 05:39 PM
Make and model of your phone?
To contact customer support :
Submit a support ticket via Simple--Simon the chat bot Click here
Or if you prefer or cannot submit a support ticket you may send a private message : Click here
To pre-verify add in your private messaging only your full name, address, email, phone # & 4 digit account pin #
05-04-2022 07:51 PM
@chch518 Sounds like you need to input the correct APN settings for the new phone? Here's couple of links if that is the case.
https://www.publicmobile.ca/get-help/articles/set-up-data-on-an-android-phone
https://www.publicmobile.ca/get-help/articles/set-up-data-on-an-iphone
05-04-2022 07:49 PM - edited 05-04-2022 07:50 PM
First off...log in to your account / My data and add-ons to see how much data you've already used up. If you see no mention of data...that means you've already used it up.
