why are my data add ons not working
new_newnick
can some explain to me why my data addons are not working i just spent 20
9 REPLIES 9
TMS
Log into your account and select Plan and Add-ons
scroll down to Add-ons
make sure the add-on is listed there.
If not, you’ll need to notify a moderator.
missorange
it should be working right away as I purchased the data add on. unless you purchased the us roaming add on(wrong one) but using in Canada.
TMS
...and that you are not using a US addon within Canada 🇨🇦
TMS
If you purchased the US addon(s) make sure you have data roaming turned on.
@hairbag1 wrote:
Which data add-on did you buy ? PM has a $30 and a $10 option....none for $20. Please confirm and let us know.
The language is plural so maybe they got two $10. 🙂
@new_newnick
Did you turn on the data mode of the phone?
What make/model phone is it? Maybe it's not compatible with the data services here.
Then there's the APN settings.
Find your phone on this list:
Officially Recognized APN Reference
If your phone isn't there maybe these might work:
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
hairbag1
Lieux
More details would help us to help you @new_newnick Smiley Happy
hairbag1
Make sure that your APN setting is correct. What type of phone you using ?
Alex888
Did you add funds to your account before buying the addon? Did you buy a US or Canada addon? Does the main page of your account show the addons?
Can you post a screenshot of your account, with personal data removed?
