02-12-2023 11:59 AM
02-12-2023 06:58 PM
Hi @pugo
turn off device, and turn back on, and call to yourself phone number from same device, and set up..
02-12-2023 01:21 PM
Voice mail has to be set up very fist time (and only once) using your mobile phone, not calling from other phone.
Did you set up your voicemail ever? Did you accidentally apply anti spam trick Not to record Any voicemail at all?
02-12-2023 12:27 PM - edited 02-12-2023 12:28 PM
At Public Mobile, all plans include voicemail, call display, and conference calling.
How To Set Up Your Voicemail Greeting:
Your voicemail is automatically ready to accept messages. Until you set up your voicemail greeting, the default system greeting will be played.
To set up your voicemail greeting: 1. Hold down the “1” key on your phone keypad. This will dial your voicemail access number. 2. Follow the prompts to set up your password, and record your name and personal greeting.
To retrieve your voicemail messages from your mobile device, you can either:
How To Access Your Voicemail From Another Phone:
How To Reset Your Voicemail Password:
You can change your voicemail password using My Account or by dialing into voicemail.
To change your password using My Account:
To change your password via voicemail:
02-12-2023 12:09 PM
@pugo mond to explain what not working? you cannot chexk VM ? or people cannot leave you message??
it ever work before or just stopped working??
02-12-2023 12:01 PM
What part? Dial 1-778-580-4001 to see if it's there. Or have you just transferred a number in?
