voicemail problem
11-01-2022 08:07 PM
when someone calls my number and i don't answer, the call does not get forwarded to my voice mail.
the caller receives "welcome to the voice mail system " recording.
it has been like this for at least 3 days.
Service
11-01-2022 08:28 PM
To set up your voicemail:
1. Hold down the 1 key on your phone keypad. This will dial your voicemail access number.
2. Follow the prompts to set up your password, and record your name and personal greeting.
11-01-2022 08:25 PM
Try going in to the dialer and dialing
##002#
Maybe even
##004#
Did you recently port in? Or have you been here a while?
11-01-2022 08:18 PM
Check voicemail number in your phone. If it worked before AND you did not change anything I would contact agent for an explanation.
