Activation
SMcI
I believe that I entered the imei number from my old phone on activation instead of the new one . How can I change the imei on my new account / activation?
@SMcI you are porting your number to Public Mobile, right?
Just call the porting team.  You can update them with your account number of your old provider instead, that option is much safer then using IMEI.  I will message you the porting number team.  Please check your Community inbox
@SMcI
If the porting was successful with the old phone then all you have to do is to put the SIM in the new phone.
If unsuccessful then you need the help of a CS_Agent to complete the porting with your old account number.
darlicious
@SMcI
Did you recieve the PAT (porting authorization text) on your old Sim card? Don't reply YES instead call your old provider and cancel the port request with the incorrect IMEI#. You can then reinitiate the port request thru customer support or by calling the telus porting department. Use your account # instead of the IMEI# of your phone.
cellphoneuser1
@SMcI Your number port will fail. Use the chatbot link at bottom of the site to make a ticket. The CSA will correct it.
Outdoorsman
@SMcI hi is your phone working? was number ported successfully? if everything works you should be fine
