04-24-2020 04:25 AM - edited 01-05-2022 11:45 AM
Wasnt sure where else to ask this. Is there any way to get voicemail to stop announcing the full phone number before letting you hear the voicemail message? My previous carrier only stated the time, you heard the message, then one of the options after the message played was to hear the number it was from and time it was delivered... any way to change this? is there a setting? its quite annoying when its already in your call history...
Im thinking maybe not if we only get the basic voicemail, but i thought it was worth an ask
Service
11-25-2024 08:20 AM
Oh I'm so glad I looked this up...it was driving me insane.
05-13-2020 05:03 PM
Finally got a voicemail (yep I'm popular lol) and can confirm that this instead of the whole number just says 'new message' followed by actual message. Yay!
04-26-2020 01:23 PM
I think it's mostly just the a hold over from the days when caller ID was an optional feature.
It may also be useful for messages left while your phone is in airplane mode or out of the coverage area.
04-26-2020 03:46 AM
@brettster99 I could see maybe it would be quite handy if someone were blind or visually partially impaired that it tells them the number just in case the person didnt say their number... but for the majority of us its not needed
04-25-2020 11:39 PM
Yeah it was very annoying. Like I have eyes I can see the number that just called on the main screen I don’t need you to tell me it
04-25-2020 07:10 PM
You can change in the preferences section of your VM.
04-25-2020 06:24 PM
@brettster99 so annoying isn't it?! I mean I know, it's a first world problem, but annoying just the same lol
04-25-2020 03:10 PM
Thank you very much!!!! I was just about to ask this til I saw this post and the answer you gave. Changed mine as well
You are a hero
04-24-2020 09:20 AM
there was a post earlier that answered this question:
04-24-2020 05:50 AM
@darlicious @Nezgar thank you both for responding so fast, you're the best!
I won't know for sure until I get another voicemail but I think I've just enabled what I wanted! Or should I say disabled 🙂 thank youuuu!
04-24-2020 04:46 AM
@Pawprints1986 Now you know what to do...?.
@Nezgar Wow that was fast!! Thx ....to the rescue once again!
04-24-2020 04:42 AM - edited 05-19-2020 03:48 AM
Haha @darlicious Summoned I was 😁
@Pawprints1986You can inhibit the behaviour you describe by changing this setting once logged into your voicemail:
4. Personal preferences
2. Playback Preferences
2. Disable playing of the caller ID
04-24-2020 04:34 AM
This is when you use the @Nezgar bat signal. Resident voicemail expert extraordinaire.
