11-24-2024 09:11 PM
Hi,
I saw this $23 plan come with 100 LD mins per month. But it didn’t mention about the call display, call forward or voice mail etc.
Does this $23 plan including all these features or not? There is a $23 plan previous very similar, the only difference is the 100 LD mins, Are they the same or those features have been taken out?
Thank you
11-25-2024 06:44 AM
@Jsmart if you are currently waiting to change on renewal, the 100 international minutes is not shown. One your renewal is completed, you will see the 100 minutes. I went through the same thing when I made the same switch.
11-24-2024 10:05 PM
If you go to switch subscription you can double check the plans available. You can make the change immediately or choose to have it done at renewal. I noticed there were a handful of plans with slight differences with a fairly close monthly cost.
11-24-2024 09:53 PM
Thank you for the clarification, I just switched to this $23 plan. Now the descriptions included these features, but not the 100 LD mins, so confusing.
11-24-2024 09:13 PM
Yes, this $23 plan includes the regular features.
All PM plans include call display, call forwarding, voicemail.
