11-12-2025 08:56 PM
How do I confirm what international countries are included in my long distance phone plan? I've tried looking through the breakdown (it just says 7 countries) and my specific plan isn't on offered anymore so I can't check there either. Is there a specific way I can check?
11-13-2025 08:59 PM
Thank you!
11-12-2025 09:17 PM
I found this.
China, India, Phillipines, United Kingdom, Pakistan, Taiwan Hong Kong.
If you have the Public Mobile app, it has it under Add-ONS.
11-12-2025 09:11 PM
I have the $29 ULCWUSMEX Base Plan but when I press the Usage Breakdown button it just say "100 LD minutes 7 countries".
11-12-2025 09:07 PM
Which plan do you have? Usually if you click on Usage Breakdown, it will show you the countries included.
