Phone not working in the United States
Waynedr
Phone won't call out or receive calls
Wasif
Check your plan details to see if unlimited call/text is supported in USA .
Dunkman
@Waynedr
Check the VoLTE IME checker on the link that I sent earlier.
https://www.publicmobile.ca/en/get-help/articles/volte
I pretty sure that Samsung A70 is not VoLTE compatible and you will have talk issues while traveling in USA.
porcupine
Did you turn on roaming also did you pick  At&T or T-Mobile
Waynedr
Texting is working
Waynedr
I'm using a Samsung galaxy A70
Dunkman
@Waynedr
Does data and texting work?
Which model phone are you using?  with traveling to USA, your phone needs to be VoLTE compatible with PM network since the 3G network has be decommissioned in the USA.
https://www.publicmobile.ca/en/get-help/articles/us-roaming-troubleshooting
