My Plan includes unlimited long distance calling, but calls do not go thru
yvrvagabond
My plan includes unlimited phone calls within Canada and US.  But when I go to call Ontario, I get a message that I have used all my long distance minutes.  I have even wasted $5 to purchase a long distance add-on, even tho my account includes long distance.  Same message;  I have used all my longdistance minutes.  Local calls are ok.
I have tried dialling 011 to exit country, then 1 for country code, then the number.  Also just 1 and the number;  no luck either way.
I would appreciate if anybody could guide me in how to proceed.
yvrvagabond
Thank you so much!!  Simple network refresh and reboot worked a charm.
Chalupa_Batman
It just sounds like you need to do a network refresh. Go into your settings and and find Network Settings. Refresh them and reboot the phone. Then contact a CS Agent ask ask them if they'd be willing to credit your account the $5
If you are able to log in, please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket. Enter CONTACT US into the chat and follow the prompts.
If you’re unable to log in to your account, please use this direct link to reach out to a CS Agent.
hi @yvrvagabond are you just calling from Ontario to another Canadian number? then yes, it is included
 reboot phone and try calling again
or ask PM agent to refresh the account
please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
