01-25-2017 09:08 AM - edited 01-05-2022 01:38 AM
01-25-2017 05:15 PM
@hedwig did you complete both steps of the add-on purchase? At first it will prompt you to add funds to your account, but you then have to go back and actually purchase the add-on with the funds you previously added to your account. If you sign into self-serve, do you see an available balance of $15? If so, you haven't completed the purchase, only added the funds.
01-25-2017 10:35 AM
01-25-2017 10:31 AM
01-25-2017 10:28 AM
Has @Mary or @Shazia_K reached out to you yet?
If you haven't already, provide your public mobile phone number via a private message for help. This should be sorted fairly quickly.
01-25-2017 10:26 AM
01-25-2017 09:32 AM
01-25-2017 09:29 AM
Make sure that the data roaming option is enabled in your phone settings.
