upgrade to 4G
Kim25
Hello Community,
I am still on a 3G plan ( from way back), and want to upgrade to a new plan. Will I be able to keep all my rewards, free data etc.?
thanks in advance
8 REPLIES 8
Godzillaz
Yeah this is funny
I still have a legacy extra minutes booster
I dont think Public even offers plans with limited minutes anymore so that addon will stay on my account forever I think
Godzillaz
I know its a 3G plan but is it actually?
I had a VERY OLD legacy 4G plan
One day I logged into my self serve and it was changed to 5G
All other features are identical and all addons were not expired (plus the fact that plan was never even offered in 5G days)
I am pretty sure Telus (Public) will shut down 3G soon (I know Koodo no longer even allows it; connecting to 3G in poor coverage areas will cause you to incur an additional use fee on your monthly bill)
hairbag1
@Kim25
remember that you won't be able to downgrade back to the 3G plans...they gone now.
Kim25
thanks for info!
Kim25
thanks very much. will upgrade.
HI @Kim25
yes, plan changing won't affect your rewards and free data and LD option you got from Christmas before.  They will all be there
make sure you use Change on Renewal option to make the plan change
Phil_Adelphus
@Kim25   Yes you don't lose any of the bonus data or minutes when you upgrade your plan, nor do you lose any referrals.
slusagm
yes, you will keep everything even after plan change
