12-30-2022 10:13 PM
12-31-2022 02:50 AM
You can change your plan on your account. However, you need to wait a month to change plan if you have a new plan.
12-30-2022 11:22 PM
I'm thinking a little chat with the kiddo is in order.
Then, ask the customer support agents to remove the account from promotional type offers via SMS, but ask if they can remain via email to only an account YOU can access.
12-30-2022 10:19 PM
@daniel122 @Did your son reply YES to a text maybe to except the offer by accident.. either way that’s a great plan … also did you get your merrier is more bonus data and international long distance, if not you will need the help of a agent to have the bonus data and long distance minutes manually applied
Getting help from agent , through automation
Or get direct help from a agent right here in the community ( my preferred choice )
12-30-2022 10:15 PM
@daniel122 PM has send promo text earlier and ask people to upgrade to the new $40/15GB plan. All you need to do is to reply YES. It was possible you or your son has replied YES and hence the upgrade was scheduled. Check your text history to confirm
You might need to go back to My Account and go to Plan & add-on page to change it back to the $15 plan
or if you like to discuss with PM support, you can open ticket with them. But PM is prepaid and usually won't do much in such case. To open ticket:
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
12-30-2022 10:15 PM - edited 12-30-2022 10:18 PM
You should probably reach out to a Customer Support Agent and have them look into your account.
Use the Chat Bot Simon to get a service ticket started first.
If you have trouble getting a service ticket started, then you can send a private message to CS_Agent for help too.
