upgrade from $15 plan
12-30-2023 06:39 PM
I haven't ever had to buy Data. 250mb is fine. and only buy minutes a couple times a year. If PM wants more money from me I would consider upgrading to the $24 /4GB plan. why isn't it available to customers like me ? I feel if PM targeted users like me to switch PM would make more $
Plans
01-29-2024 10:19 AM
I was on the $15 plan and I finally switched this month to the $24 plan. You'll just have to wait, I guess.
12-31-2023 11:39 AM
It really depends @JenCanada
You have to look at what plan you have now, if you are on the legacy rewards system or the new point system. Do the math and you'll be able to figure out if it's worth switching over or staying put. Make sense?
12-31-2023 02:04 AM
I agree with you.
Would I save more money with old plan compared to new one
12-30-2023 10:55 PM
I've had enough, fido and other companies are offering 30g for $29....time to leave
12-30-2023 09:46 PM
Maybe you will be on the next list of targeted $15 plan subscribers to get the text offer of the $25/5gb plan ? Keep your fingers crossed.
12-30-2023 07:43 PM
There are plans option that you can pick to upgrade from your current plans. Be sure to check the subscriptions page for any plans that interest you.
12-30-2023 06:45 PM
Hi @LiveLime
Not really. And I don't see it that way. You can change plans at any time. You just have to weigh out things. Lose your number or port out then port back in. You'd lose your Legacy Rewards too. You have to weigh the pros and cons.
