txt to Australia
01-08-2020 03:52 PM - edited 01-05-2022 08:56 AM
01-08-2020 06:10 PM
@Forrest wrote:Hi,
I have a plan with unlimited international txt. Sending a txt to the Netherlands works but to Australia not. Any idea how come?
Thanks
I am able send text messages to Austalia. I would iamgine that the two carriers involved would have to have some type of agreement with each other to deliver each other's text messages. There's also a n intermediary company involved whenever messages go from one carrier to another. Delivery success may also be dependent on the carriers involved, and not necessarily just the country.
01-08-2020 05:19 PM
Be sure to enter number correctly, including country code and area code.
01-08-2020 04:55 PM
@missorangeThere isn't really a list for sending texts internationally nearly every country is included with exception of a few closed/isolated countries such as North Korea.
01-08-2020 04:46 PM
@Forrest wrote:Hi,
Thanks
@Forrest I have relatives in Australia also, with the fires and loss of infracstructure in some areas, it might be on the receiving end. Also with everyone contacting loved ones, it just might be overwhelming their system.
01-08-2020 04:31 PM
@ForrestInstead of replying try sending the text directly by entering the number. If it still doesn't work then more than likely the issue is on the receiving end.
01-08-2020 04:18 PM
number I use is correct; still it does not work even after rebooting my phone. I wonder if it has to do with the receiving phone.
Will find out.
Thanks for your replies and suggestions.
01-08-2020 04:10 PM
International calling and texting follows the following format
011 + country code + area code + phone number
011 is the exit code from Canada.and US
01-08-2020 04:01 PM
yes , I am able to receive a txt from Australia. When I want to reply I get the message "not delivered"
Will reboot my phone, thanks for that suggestion.
01-08-2020 03:56 PM
@Forrest wrote:Hi,
Thanks
Shouldn't be a problem. Check your country code and area code. Possibly strip leading zeros.
01-08-2020 03:56 PM - edited 01-08-2020 04:03 PM
Are you able to receive texts from Australia ?
Try rebooting your phone.
Omit the leading zero and use +61.
01-08-2020 03:54 PM - edited 01-09-2020 10:49 AM
Make sure you put the right country and area code.
