12-21-2023
11:25 AM
12-21-2023
05:35 PM
computergeek541
12-21-2023 11:30 AM
@Morfey82 Thenyou can contact support using this direct link
send a private message To CS_Agents
12-21-2023 11:30 AM
Subscription not activated. Contact a customer support agent
12-21-2023 11:29 AM
I was trying. It said I need support service
12-21-2023 11:28 AM
I was try but is said I need to contact support
12-21-2023 11:28 AM
@Morfey82 Is your Koodo pre paid like PM or post paid ? If pre paid you need to create PM account with temp PM number then get support to transfer the number for you
if Koodo post paid you can do this in activation on the PM app . If you have already and didn’t reply YES to the confirmation text to port from Koodo sim . Then I’ll send you the porting team number private message and they can re trigger the port request for you
12-21-2023 11:27 AM
HI @Morfey82
you started the process yet?
if you are from Koodo Postpaid, just activate PM using PM app, and enter Koodo account number on the porting step
if you are from Koodo Prepaid, then activate with a new number first and then submit a ticket with CS agent for manual porting help:
But if you have porting problem, tell us what the issue is
12-21-2023 11:27 AM
Public Mobile is self serve. You have to do the activation yourself...online.
