07-09-2026
10:42 PM
08-15-2026
11:04 AM
Dunkman
Hello,
I recently changed my subscription to the $50 plan but I no longer need that plan. I tried to change my subscription back to your basic one which costed me $21.56/month tax in but there is no option online. Could you change my plan back to the basic one please My number is ###-###-#### and email is ******@***
07-09-2026 11:10 PM
hi @jasonnnn downgrade is possible but it might take time
but the $18 and $19 plans are old plans now, not even for new subscription. you can at most get back to $29 but again it takes time
choose the cheapest plan to change first., use Change on Renewal. Then after you changed to that, check again and hope they will give you an even cheaper plan
07-09-2026 10:43 PM
sorry...once you've opted for a higher value plan it's very difficult to downgrade to much cheaper plan. Just hafta watch your account to see the plan offerings.
