2 weeks ago
Hi I am trying to complete my activiation and when I put in my phone number to transfer it says it is not a canadian number even though it is. I am not with Koodo I'm currently with Virgin Mobile and when I try and chat with a live agent I just get disconnected.
2 weeks ago
Try submitting a ticket with support . Using the chat bubble bottom right of screen.
⬇️ Click the link the here * ⬇️
If the link above doesn’t work correctly OR you don’t have access to Log In, please go here to send privare message to CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
2 weeks ago
so I have even tried activating with a new number and then going to self serve and transfer number that way and it says number not eligible for port.
2 weeks ago
the number is still active with Virgin and it is not a landline.
2 weeks ago
Is your account still active with Virgin mobile?
Was this number previously a landline for you?
2 weeks ago
519
2 weeks ago
Maybe you will find this solution helpful
2 weeks ago
What's your area code?
