06-22-2023 10:05 AM
my phone was stolen on June 20 in the evening (around 6 pm atlantic time). I suspended the service and reported it stolen, however I checked my history and the phone was used last night/morning at 3 am (June 22) and they can still use my data! I'm not paying for that. Can someone just deactive the phone/sim for me. any activity after June 20, 2023 is not me. Thank you
06-22-2023 10:40 AM
How did you suspend service?
You should report as lost/stolen and service 'should' seize immediately... unless that is not working properly...
06-22-2023 10:16 AM
@TD156 wrote:it was about 30 MB, I read it wrong as 30 GB, but it is saying I am over my data limit, and I never go over it, and I'm not up at 3 am
Public mobile shows a summary of your data usage (not live time usage). For example, my data usage usually shows up in 1-2 readings at about 1 AM every night even though I am asleep. Check your past data usage over the last 1-2 weeks and you should see 3 AM reading also.
There is a data reporting problem this morning. Errors showing incorrect data usage, etc. PM is made aware and should be working on a fix.
ie.
06-22-2023 10:14 AM
Thanks, I just messaged them, I couldn't find that info anywhere!
06-22-2023 10:12 AM
06-22-2023 10:08 AM
Was it a lot of data used? Public mobile will report usage one or twice per day as a summary usage. There may be a small amount of data usage/leakage even in lost/stolen mode.
06-22-2023 10:07 AM
