sim set up
Valma1
Hello,
I am setting up an account for a friend but I am having issues completing the task.
Payment withdrawn from my account, email received to complete in app but it keeps telling me
the email is not valid.
please help.
Juanita
Valma1
Hi all, thank you for for the suggestions. I inserted the sim into my personal phone and it proceeded to complete the setup.
Cheers
@Valma1
Did your friend pick a new number or ported their old number over to PM?
If it is a new number, reboot the phone by powering off then back on.
If it was a ported number, the old SIM will continue to work for about 90 minutes to 2 hours until the porting process is completed then power off the phone and switch the SIMs.
Valma1
So far no lock out messages.
@Valma1  Can be cache issues when you try again . Try incognito or private mode or even a different device . And note too many attempts can lock you out for a full hour . But you would also get a email indicating so at that point
Valma1
Thank you for the info. I will recheck everthing but I received multiple codes but none worked.
I might need to check on the email option also. But why would it assign an account #, accept the email and payment then to just give me errors?
@Valma1  Is it the same email you got welcome email from PM ? If you’re being asked to send code . Try tap re send code or didn’t get code option then you should get option to send code to email instead . If this friend was ever with PM before you will need to use a different email then before .but if you need support here’s the link
private message   To CS_Agents click
