08-07-2026 11:03 AM
Unless I am on full bars, my data works significantly slower and completely stops if at 2 or less bars. I have tried resetting phone, settings, and even got a new phone.
08-07-2026 11:21 AM
08-07-2026 11:14 AM
@J_Bug wrote:No my familys data works completely fine which makes the more confusing for me.
As long as we're all using hard sim, try swapping sims to see if things improve in your cell. This suggestion won't work if we're using esim.
08-07-2026 11:07 AM
08-07-2026 11:07 AM
hi @J_Bug
which city and province? And only data has issue but voice calls working well?
There have been some outage in different part of the country and that could be the reason of your data issue. Please check Telus outage site:
https://www.telus.com/en/on/outages
or you might want to report the issue to Public Mobile support. Submit a ticket with CS Agent using Chatbot here:
Type the question "Ticket", Then click the following in order: "Account Management" , "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
08-07-2026 11:06 AM
ask PM to help to check , Simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.) When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
PM will reply to your community inbox, between 9AM-10PM EST (Mon-Sun), check here:
08-07-2026 11:06 AM - edited 08-07-2026 11:07 AM
do others around you experience similar issue ? If you travel around your area does signal improve ? Could be a local network upset or some repair being made to tower. Try using 4G/LTE instead of 5G.
