03-05-2021 04:27 PM - edited 01-05-2022 05:30 PM
Im getting all kind of error, even log out when i go to Plan TAB. all other tabs are ok.
03-05-2021 08:46 PM - edited 03-05-2021 08:51 PM
this always happens at high peak hours. from 6-10pm eastern time
03-05-2021 08:46 PM
@HALIMACS : No just the overview page. Says My Plan and then the next line is your plan. If that's not there then it's in its mood.
03-05-2021 08:44 PM
@Anonymous
Plan details?
I don't see em, just get this:
I do hope this isn't anything nefarious going on... seems a poor move on Public Mobile's part not to otherwise inform it's customers beforehand of limited self-serve functionality.
03-05-2021 08:38 PM
@HALIMACS : I can't say as I've ever noticed a substantial difference in the site after these moods.
I'll be looking for the anomaly I mentioned long ago though.
03-05-2021 08:32 PM
@Anonymous wrote:I've seen this many times in my time here. I call it being in a mood. The primary clue is if you don't see your plan under My Plan.
Has anything substantial by way of changes generally followed these instances @Anonymous ?
Especially when coupled with the changes being unannounced beforehand as 'scheduled maintenance'?
03-05-2021 08:24 PM
03-05-2021 08:17 PM - edited 03-05-2021 08:18 PM
@HALIMACS wrote:Yes, @dabr , there was an update a little while back.
I'm guessing it may have had something to do with the new Activation portal, but that's just a guess.
This one seems different - seems odd users are unable to view so many items within self-serve and Public Mobile did not notify of anything in advance.
@HALIMACS Yes it's possible it may have something to do with a new Activation Portal, but PM has had ongoing issues with their self serve pages many times before and although normally the issue just last couple of hours, I believe we have had longer timed problems before.
Probably would have been a good idea to give everyone a "heads up" first if this was planned beforehand though...oh well, it is what it is!!
03-05-2021 08:12 PM
03-05-2021 07:59 PM - edited 03-05-2021 11:29 PM
being like an old grump
03-05-2021 07:55 PM - edited 03-05-2021 08:07 PM
@HALIMACS wrote:They definitely are doing something, try the Change Plan feature.
No options to select.
Was there any notification of planned maintenance?
My account has been stuck on My Profile and I can't seem to log out...
Edit: So finally got the Change Plan option page and there's no plans to change to (edit: as noted by Halimacs) ...definitely something is being updated, perhaps an improvement? 😁
Don't remember any new notifications on maintenance...didn't we just have one just over a week or so ago?
03-05-2021 07:53 PM - edited 03-05-2021 07:53 PM
They definitely are doing something; try the Change Plan feature.
03-05-2021 07:51 PM - edited 03-05-2021 11:28 PM
sorry for...
03-05-2021 07:50 PM
@dabr wrote:
@RosieR wrote:
@MoreYummy wrote:Im getting all kind of error, even log out when i go to Plan TAB. all other tabs are ok.
@MoreYummy I just logged in my self serve account and you are right. All the tabs are working except the Plan and Add-Ons which gives this error response.
PM must be doing some update.
RosieR
@RosieR You're right! Just tried it myself...I wonder if PM is getting ready to remove the "sale" prices on those plans...hmm.
@dabr you may be right. 🤔
03-05-2021 07:45 PM
RosieR
03-05-2021 07:41 PM
RosieR
03-05-2021 07:22 PM - edited 03-07-2021 02:17 AM
@MoreYummy what I've observed is when you log in to your self serve and it doesn't show the plan amount in the 'overview' tab then the plans tab will not work at that specific time. you will have to try again another time
here's an example of when the plans page will be guaranteed to work
03-05-2021 05:15 PM
@MoreYummy - it is slow for me.
Navigating is working, just super slow.
PLEASE PM make the SELF SERVE better - pretty please....!
03-05-2021 04:33 PM
Maybe a timeout error. PM site is generally slow and quiet some timeout error.
Relax.. wait a bit and try back, I bet it will be ok after awhile
03-05-2021 04:31 PM
Try clearing your history cache and cookies. Then use Chrome incognito for the browser. Then try again.
03-05-2021 04:30 PM - edited 03-05-2021 04:31 PM
@MoreYummy PM's website can get very glitchy from time to time. Just trying again in another half hour or so usually does the trick. Make sure to also clear your cache/cookies and use a different browser with incognito/privacy mode enabled.
