04-27-2024 07:18 PM
how do I request a refund for add on service for data roaming that doesn't work?
it worked in Denver but when I hit omaha I get error message. I am not satisfied with this add on and would like to cancel. I will added it on for 3 days.
04-27-2024 08:04 PM - edited 04-27-2024 09:28 PM
If your phone is 5G capable, have you tried changing your phone setting to 4G/LTE? And also changing the network setting from automatic and then manually selecting T-Mobile or AT&T?
04-27-2024 07:38 PM
I read on here somewhere that you need to manually connect to t-mobile or at&t if it's set to auto it may be your problem. I could be wrong I'm sure someone will correct me if I am.
04-27-2024 07:27 PM
You can open a ticket with agent but I really doubt they will issue a refund.
You did admit it worked in some state(s) but not in other meaning add-on works. Just because you are 'not satisfied' is not really reason for refund. If it did not work at all, then you might have chance.
04-27-2024 07:26 PM
Hello @calistocolin
Please create a ticket
To Submit a ticket, please click the following link to access the Public Mobile Chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type: Customer Service Agent
IMPORTANT INFORMATION: I am not a Public Mobile employee. I am a customer just like you. Please do not send me a private message with your personal information.
04-27-2024 07:22 PM
if it works briefly but not the full trip, PM might not give a full refund.
But try and ask and they might do partial. please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
