3 weeks ago
my phone says no service but is connected to the wifi.
More than just a couple of times, I have tried: rebooting phone by shutting it down, reinserting the SIM card (i was using a different SIM card for 2 weeks in another country), switching between airplane mode and not, checking my updated IOS system (it's updated).
It seems that i have to shut down the phone completely and restart it every time i want to send or receive a text or phone call.
Any suggestions?
3 weeks ago
yes, it's an iphone. I don't have a dual SIM and don't see where to set it as primary
It doesn't seem to make sense that it shows it has service with Public Mobile and then service disappears
thanks for the help though
3 weeks ago
hi @chr1 is that an iPhone?? make sure the PM sim is set as Primary
3 weeks ago
Yes, used a new sim card when travelling. Removed it and put the public mobile one back in. It shows public mobile in the top corner at first, but then goes back to showing no service. I did click reset settings as you suggested. I thought it worked but again, the no service shows up.
How do i delete the other SIM card? it was an actual sim card, that i inserted into the phone.
3 weeks ago
thanks for the reply. Yes i have tried that. the SIM card seems to work, but it's on (shows Public Mobile in the top corner) but then off again showing no service.
3 weeks ago
Have you tried resetting all the network settings? Also, have you tried the SIM card in a different phone to make sure it still works?
3 weeks ago
